hhsting
- Glen bunie, md, us
- Junior plan reviewer
Please see attached three phase transformer its primary is 480/277V and secondary is 240/120V i.e delta with 120V center tap.
Spec sheet says primary connection Delta and secondary connection is delta w/center tap.
In addition to attachment please see below link that has wiring diagram of transformer.
gcc02.safelinks.protection.outlook.com
Questions:
1. Would the primary windings be delta or wye? Would secondary windings be delta or wye?
2. Do I need to ground both primary and secondary or just secondary or just primary per NEC 2024 Section 250.30?
3. How does one ground this transformer if windings are delta?
4. Is transformer separately derived or not?
Larson Electronics - 45 kVA Isolation Transformer - 480V/277 Wye Primary - 240V Delta w/ 120V Center Tap Secondary - NEMA 3R
Questions:
