mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2023 NEC
Good feedback, thanks. At least I know its not a common off the shelf item. I didn't want to put effort into this only for someone to say "Why didn't you use this...."
Thanks.
I wonder what the lead time would be on ... 1 ?Kyle and Mulberry both say they make custom plates on their respective sites.
Do you mean before or after the laugh-fest?I wonder what the lead time would be on ... 1 ?
Nice find!They also mentioned a completely blank 4g plate for DIY:
Four Gang Completely Blank Switch Plates with No Holes
4 gang screwless blank switch plates in stainless steel made in USA. Find 100's of sizes, matching switches & outlets, fast shipping, easy ordering at Kyle Switch Plates.www.kyleswitchplates.com
YEPYou mean something like, "Why didn't you just use two separate boxes?"?
I think I am just going to put them in 2 separate 4" square boxes and nipple them together. It will be surface mount below a panel. I did humor making one because I have access to a Tormach CNC mill.
I love MCMASTER for CAD files and sure enough they had a CAD file. So I was going whip up a CAM file in solidworks using HSM works for CAM and mill it, but then I thought what am I doing. It does not need to be so pretty, I just thought there was a neat solution besides the usual 4" square. I don't want to custom order one, just because that would be more of a hassle than making one. So 2 separate boxes it is, the usual.
