Why am I getting 90V with three way switch off.
I had a customer today wanting to be able to control his kitchen light by two switches. Should have been easy I’ve done it thousand times. So I started with running a three wire from his existing switch to a new switch location. Came off the existing hot and neutral for power. When I was done wiring it up and turned the circuit back on I got 90V from hot to neutral at the light fixture with the switch off. 120V when the three way was on.
I thought maybe pinched wire or induction.
I ran a new three wire on the ground this time just to test it to make sure my wire wasn’t damaged and I got the same thing 90 V in the off position. I’ve then ran a new home run from the panel to the switch, And also a new switch leg. Still had 90V from hot to neutral?
