Of course it's not new, but it is a great splice if done properly.In my old age, I watch a lot of videos on Youtube. The author of the video aeems to think that it was something new. Its advantage is superior pull strength which would be needed with overhead single wires.
Wow, did that ever bring back a memory! When I was six and in the first grade, I found a book in the school library about radios, including how to make a foxhole radio. (I was reading way beyond Dick and Jane by then.)Learned to do those fifty years ago when string ham radio antennas.
Yup. Western Union Telegraph is going to replace cell phones any day now.
-Hal
Learned that 65 years ago in the electrical portion of my USN electronics school.Wow, did that ever bring back a memory! When I was six and in the first grade, I found a book in the school library about radios, including how to make a foxhole radio. (I was reading way beyond Dick and Jane by then.)
I strung a wire from a stand-off insulator I attached next to my window out to a tree, with a porcelain egg insulator. The head of my bed was next to the hall-bath tub cut-off valve access panel, so I had a ground handy.
Yup, likewise. And before today, hadn't heard a peep about them for almost thirty years.Learned to do those fifty years ago ...
Solder pot? Solder iron, I get, but not using a pot for a WU splice.the EC I apprenticed to taught me how to do them. I was still using them to some extent as recently as 2010, which is when I finally put away my solder pot and started using wire nuts. Now I use push ins. What a world.
I helped a friend rewire an older house. We soldered all the splices and wrapped them with rubber tape an then with "tar" tape.Solder pot? Solder iron, I get, but not using a pot for a WU splice.
Did you use a solder iron or a solder pot?I helped a friend rewire an older house. We soldered all the splices and wrapped them with rubber tape an then with "tar" tape.
We used an iron heated by a blowtorch which burned white gasoline.Did you use a solder iron or a solder pot?
Thanks.We used an iron heated by a blowtorch which burned white gasoline.
Learned it in vo tech school but while a field wireman in the Army we had twisted #16 guage 7 strand wire for telephones. 3 or 4 of the coated wires were steel and the rest coated copper. Would make western union splices 6" apart then tie wire to 2 poles and sit on it for a minute. If splices were made correctly would support you. In Nam some clowns would cut our phone lines down and use them for clothes lines. Was great when you had a load on and wire caught you in the neck. After a few of these runs ins always carried wire cutters with me to fix neck breakers. Young sparkies probably never heard of them.Of course it's not new, but it is a great splice if done properly.
