ctclark1
- Western New York
- Electronics Technician
I'm looking at a stop-gap measure to replace some of our 400w MH parking lot light lamps with LEDs (corn cobs, 120-277v rating) as they burn out until we can get a full project in a year or two to replace them with full LED fixtures (for other reasons that will include pole replacement at that time, which is why we just want a quick and dirty fix for now).
The power to the poles is single phase 480v (2 legs of a delta system to each pole), so 277v is not available.
Someone from an electrical contractor we had in here a few months ago had told me to just leave the ballasts in place and that would be ok. While in theory this makes sense to me as part of the ballast is a transformer, I never thought about what the output voltage would be until recently. I'm finding a bunch of different information online, with regards to the open circuit voltage being much higher than what appears to be the roughly 150v that a mh lamp would use (closer to 300v open, which would be too much for the led, I don't know if the led would be enough load to bring that down to the "working" voltage). Part of me also says the capacitor should probably be removed from the circuit if the transformer theory holds up.
Is this something anyone's every heard of? If this doesn't seem right, short of buying a bunch of small 480 to 240 control transformers and replacing the ballasts anywhere were put the corn cobs, are there any other viable solutions for quick and dirty?
