Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
I wish to install a hp rated disconnect for one of our air compressors so I can have an auxiliary contact to block one other compressor from running at the same time. It doesn't seem to have an input to block it from running, so I need the auxiliary contacts to force people to turn it off before starting the other. The other compressor has a control input to block operation.
The logical place is directly under the subpanel that feeds it. This would put it not quite 36 inches above the floor. Is that still OK?
Thanks.
Thanks.
