550.33(A)(1)
Fred B
Upstate, NY
What is the rationale for this section where it states "a permanently installed feeder consisting if four insulated, color-coded conductors......" ? Why the insulated grounding conductor requirements specifically for mobile homes? Anyone involved with the panel that considered this have insite and discussion that led to this requirement? How does a person get access to such?
I'll bet you it has something to do with the cord and plug type. Not sure, though. But , is that permanent? I know some still plugged in today that were wired in the 80's
It does have exceptions.
Lemme look.
Okay, looked. My guess is because that's how cords are made, and they wanted to mimic that.
More likely is that it might somehow be a way to reduce accidental energization of the chassis.
Mobile homes have required non-bonding and 4-wire major-appliance circuits for almost forever.
Cord and plug is in same section but different criteria, also not considered permanent. Permanent is what might commonly be referred to as hardwired.
Lemme look.
Item 1, could be, but find it hardly a reason to make it a rule.
Item 2, not sure as the chassis has to be bonded to the grounding bus and conductor as listed in another section. And not sure how having a insulated ground would help this.
Item 3, that's true, no neutral/ground bonding.
Trying to discover the underlying reason for this installation to be different than a similar installation in a non mobile home. Can see needing to justify it to a GC sometime.
I never understood the "color coded" part. Never seen it enforced other than the normal white tape on the neutral and green tape on the EGC.
