I don’t understand what the big deal is. It’s all in conduit. They should never have to remove or work only the wire. If they do they disconnected at the transformer. The other conduit isn’t going to magically remain energized if the source is off.POCO doesn't like the two conduits in the same trench. They are in the same trench from the trans pad to the house, from the trans pad, the trench turns and goes to the separate building. There is only a single conduit from that point.
