euboss
- Fort Myers, Florida
I am trying to determine if a neutral is required at a subpanel that has only 2 pole breakers and the equipment does not need a neutral? as in HVAC equipment. My concern is if someone adds a 120 volt circuit to the subpanel they would only be able to connect the neutral to the EGC and potentially cause a hazard. My Inspector says it is required although i can't find it in the NEC .
