Bogiedown170
- Yonkers, NY, USA
Hi, I’ve looked at NEC and cannot find and need help understanding if a 2.5” offset nipple can be used on a meter pan for Rigid.
Basically we installed a 2.5” meter hub for a 2.5” rigid but as you can see from picture, we could not get the opening on roof close enough and gap from meter pan to bottom of roof line gradually separated to approx 3”.
the alternative was to use a 2.5” meter hub then attach an offset nipple and pipe would have been spaced evenly from pan to bottom of roof line. Is there anything in code that prohibits this? I’m in NY, Westchester County
