threefie
- United States
- Retired Electrician
I have had some bad experiences with 2 wire circuits and GFCI receptacles. More specifically, when installing a GFCI receptacle on a 2 wire system and protecting other receptacles / appliances from the load side of that receptacle. If you mistakenly hook up the ground wire from that outlet downstream, you will receive a shock if you touch the grounding conductor...correct? Could you please explain this phenomenon?
