xguard
- Baton Rouge, LA
Masterspec has the following tests for panelboards under "field quality control".
1. Test insulation resistance for each panelboard bus, component, connecting supply, feeder, and control circuit.
2. Test continuity of each circuit.
3. Initial Infared Scanning - (each panel board)
4. Follow-up Infared Scanning -(each panel board)
We typically only require insulation resistance testing for roadway lighting and not for office buildings. We've never called for infared scanning on any projects that I know of. Are these tests commonly performed for office buildings? I don't want to specify unnecessary tests just because they're an option in Master Spec. I'm asking about the initial design projects and rehabilitation projects, not from a maintenance perspective.
