Ok, so you think it's actually working, and it's just the lack of insulation that is causing it to not heat?No, because the moving water absorbs what little heat is generated. The housing won't feel warmer than the water.
Yes, a convertible hot tub heats very slowly on 120v. Yes, it must be covered for the heat to build up.Ok, so you think it's actually working, and it's just the lack of insulation that is causing it to not heat?
See post #25Well guys, I'm about to leave the shop for the day and am going to stop by and check on this again. I'll make sure the jets are all closed, and tell him to get some kind of cover on it and hope for the best. If not, I'll try what "LarryFine" suggested and run a temp 240 line to see if that works. THANK YOU EVERYONE for the help!
The water is moving through fast enough that there isn't enough heat rise in the water that you can feel it. To begin with it would have to raise the temp to near or above your body temp before it even starts to feel warm, so even if there is a 5 or 10 degree difference across the heater if it is going from 60 to 70 you may not really be able to tell with your hand, but I think the water is likely moving fast enough you won't see that kind if rise in temp across the heater. Might even need very precise thermometer to measure any rise in temp.I disagree with the statement that the pipe wouldn't feel warm on the discharge end. It might not feel hot but you should certainly feel a difference between the feed end and discharge end.
Depending on design of the tub, jets may be where heated water enters tub. Simple tub like I had only had two inlets to pumping system and then the jets on other side of pump. That unit did run pump on low speed during heating so there wasn't very much air introduced while heating, when you wanted to use the tub it put the pump motor into high speed.Well guys, I'm about to leave the shop for the day and am going to stop by and check on this again. I'll make sure the jets are all closed, and tell him to get some kind of cover on it and hope for the best. If not, I'll try what "LarryFine" suggested and run a temp 240 line to see if that works. THANK YOU EVERYONE for the help!
Some have a pressure switch to prove pump is running.This particular heater doesn't have a flow switch, at least not that I can tell. But the circuit board is calling for heat and the relays are operating properly and the voltage and current are both present at the heater wires. So even if it did have a float switch, it would seem to be working. Otherwise, I don't think it would call for heat, but I'm not too sure. This one really has me stumped.
Guessing if very significant element would have overheated and failed.How much limestone is in the heat exchange?
I think I was typing as you were pressing "enter"If I did research and figuring correctly it should take an hour @ 1500 watts to raise about 621 gallons of water by one deg F. This assumes no losses, real world there will be some losses even with the cover on.
If your tub holds 621 gallons of water then it would take 40 hours to raise it 40 degrees (say from 60 F to 100F)
Pass that water through the heater at 5 GPM and you are not adding all that much heat to the water as it is passing through
6000 watt heater will heat 2484 gallons by one deg F in one hour. four times rate, of course because you are applying four times the energy.
Again if tub is 621 gallons then one tenth the time would be only 10 hours to raise it 40F. Considering pump probably moves maybe at least 5 GPM through the heater, I don't think you will have enough temp rise across the heater to be able to feel the difference even at 6000 watts and if you measured it would probably be less than a degree F.
