We are wiring 3 uderground storage tanks fuel sump pumps and sensors. The sump motors are wired with seal offs. rigid conduit and EP boxes one conduit to each motor. The sensor wiring is ran in seperate rigid conduit seal off, and EP J box as it enters boundry then it homeruns to each sump sensor. The sensors are located within classified area. Does each conduit with sensor wiring need to have seal offs going out to each sump and another seal as it enters the sump pump area for each tank?? I can see where its required for enclosures and dispensers but not a J box. If anyone has experience or knowledge I appreciate your help
