curious101
- Atlanta, GA, USA
Hello,
Question regarding the above listed code section. I have a case where in the main distribution panel (MDP), a 225A/3P circuit breaker (feeding a 10kAIC MLO panel which has motors on it) is series rated with the upstream 65kAIC, 800A service disconnect with overcurrent protection. Roof top units are fed off the MDP and some condensing units off some panels fed from the MDP. Does the sum of the motor full load Amps - per the above mentioned NEC section - include all the motors in the 10kAIC panel and the roof top units and the condensing unit motors too?
I have read some posts on this code section, but it seems to me that NEC 2020 has different wording than the previous NEC versions, so it would be nice to get clarification.
Please let me know if you have any questions.
Thanks, and have a great day!
