Hi all,
I need some suggestions. I'm installing lighting control through regular power pack BZ-250 input 120-277v and Class 2 output 24v, an associate low voltage switch LVSW-101 24v, Class 2. Instead the standard ceiling occupancy sensor 24vdc, the person responsible in the job want to use a sensor switch 120-277v with 3 leads, 2 blacks(line in & line out) and 1 white (neutral) for outdoor pole function, similar to models series #s, like SBOR 10 OEX and SBOR 6 OEX. I told him that this is not occupancy sensor and will not work with the low voltage switch, he said yes, just conect the white lead with neutral and the line in and line out with the hot and switch leg and that's it. When I did it, that's no work. I tell him just bring the right 24v ceiling occupancy sensor. This is to illuminate some coolers to storage food.
I don't want to missing out something or there's another way to match these devices that they can work properly.
Any suggestions is very appreciate
