DannyG
- Bucks , PA
- electrician
...allowed in correctly fed (floating neutral/separated grounds) subpanels?
Hello all,
Would someone be kind enough to point me to the NEC article that prohibits uninsulated neutrals in sub panels?
I got flagged in NJ for not insulating the stranded aluminum neutral on an existing older 40 amp 240 volt stove circuit when converting one of 2 main panels to a subpanel. (to accommodate a portable generator circuit)
Backstory: This is the first I've heard of this "no uninsulated neutrals in subpanels" thing. It's also the first time I've seen 2 main panels fed from one bolt on meter. I'm used to pulling the meter when doing service work. Just like me, firemen can't just pull a bolt on meter either. Which I thought was insane. A utility truck has to be dispatched to kill the pole mounted transformer first. Then unbolt the meter. If you can get close enough because THE HOUSE IS ON FIRE! It sounds terrible even on paper.
It was a big song and dance to get a utility disconnect/reconnect on the same day. Mainly because they would not reconnect without an inspection by the township I was working in, on the same day. At first the utility gave me a 5 hour window to do an eleven hour job. I had to fight them. I could not do the job and have it inspected in 5 hours ha ha. It was my first job in a new utility area and they just do it different there. Thanks for listening
Stay safe
L.
Hello all,
Stay safe
L.
