There is existing conduit from one electrical panel to feed another electrical panel locates at opposite wall in the same room. The conduit run down and below the slab between two panels. The client wants to demolish and install entire new slab for the room but want to keep both panels at same spot, energize as much as possible as the panels powered other untouch areas in the building. What is the best solution for this? Should rerun overhead conduits between two panels, then remove underground conduits when new slab is poured? Other question: can the elec. panels be supported from structure above with unistrut in lieu of wall studs?
