Njonescontracting
- Saint Louis, MO
- Electrical Contractor
How do you guys wire Leviton CO /ALR 15amp switches with aluminum wire. They provide a little strip gauge and a slot to insert in.(on the outside of the side terminal) No back stabs. However, online it says to loop them. In my opinion with this slot on the outside that would be a major pain. But also says quickwire via quick connect or side terminals. Wiring straight with no loop seems tight however it is very little surface area to grab. I called Leviton today and technical support did not answer after 45 mins. What do you guys do?
