mshields
- Boston, MA
What exactly is the relationship between the sum of the load and no load losses and the impedance of the transformer.
I know that the impedance is measured by shorting out the secondary and adding a variable voltage to the primary. When you reach FLA on the secondary, that voltage divided by the nominal voltage is the percent impedance. That, it seems to me is representative of the total losses of the transformer.
So does that mean that if you do the math no-load plus load losses at FLA, you’ll get the same value?
