Has anyone tried out these pvc-bend-it tools for bending larger PVC sizes?
Looks like a piece of MC.
https://pvcbendit.com
I have a greenlee box that does up to 2". I need something to make slight adjustments to 3"EDIT: Cancel this post. I thought this was in regard to the spring based benders and didn't realize this unit used heat.
EDIT: I have had very good luck with the propane Hotbend torch and my greenlee heat box. Both work well.
I've used the hotbend on PVC up to 4" without any issues. It says it will do up to 6" pvc. The same company makes a product called Shrinkfast that is identical expect the btu output is a little less (it is made for the shrinkwrap industry). The shrinkfast models look and work exactly like the hotbend and are a few hundred dollars less. I'm sure it would probably work on 4".I have a greenlee box that does up to 2". I need something to make slight adjustments to 3"
all fine and well, until there's no power on site
~RJ~
How large of pipe can you bend with that torch? Can you kick 3" to 4"?That looks nice. Currently I use a propane torch with a fan tip. I don't usually need to bend more than a couple of pieces.
I haven't tried anything larger than 2". It makes the pipe as flexible as a hot box but for a smaller section. You do have the keep the torch in constant motion to avoid burning the pipe. Do you mean offset 3-4"? Yes, you can. It will put a 3-4" kick in a 90 as well.How large of pipe can you bend with that torch? Can you kick 3" to 4"?
i do that all the timeI haven't tried anything larger than 2". It makes the pipe as flexible as a hot box but for a smaller section. You do have the keep the torch in constant motion to avoid burning the pipe. Do you mean offset 3-4"? Yes, you can. It will put a 3-4" kick in a 90 as well.
If you had plugs that could hold a little pressure, I bet it would help maintain the roundness of the conduit while stressing it (bending).We've had a couple of the Hotbend torches for a few years. It'll do 3" conduit. We initially bought one to bend 5" utility conduit for a project. It did the job, but we plugged both ends to speed the heating process up though.
