fake_electrician
- Pittsburgh, PA
- Marine electrician
Hello, I'm a fake electrician. I work on commercial steel hull boats. I've done this for about five years. It's something I just kind of fell into.
Before this I did a little bit of residential work. I always tried to do the best job I knew how to. But, I've learned entirely on the job, and marine electric isn't quite the same. Uses different cable, different standards. Very often devices get hull grounds instead of dedicated panel grounds (this scares me)
I've worked on a wide range of equipment, from 480v 3 phase motor control centers to staterooms in floating hotels, from low voltage alarm systems to VFD drives and generators. 90% of what I do is troubleshooting. But that 10% of new installations is starting to grow, and I want to know the best way to do things.
I am constantly faking it. I do the best job I can with the knowledge I have, but I see new things every day. I am frequently humbled.
I would like to learn the best way to do things. Maybe even sit for a test and try and join a union hall, if they'll have me. I am definitely going to buy one of these massive education packages - and a DVD player! But I'm not sure if I should even aim to sit for the exam.
Here are my questions
In Pittsburgh the "Test" is a Pearson Vue F-16 (uses NEC 2014 handbook) or W-16 (uses NEC 2011) handbook.
Source
1. Should I just learn the 2020 code if I plan on sitting for the test?
1.1 How often do cities/municipalities update their code standard to the current NEC?
Both these exams are masters exams, and that's the "entry level" exam, which doesn't really make sense to me, if journeymen exist in the world.
2. How can this be?
3. Do any states have reciprocity between them for licensing? Of course it will be easier to sit for a national exam the second time, but - besides that, does it get any easier?
4. I see on the NFPA website that the 2020 code is available as Code or Handbook. Their price for the handbook is $211. Is there any reason NOT to just buy it on a site where it's half the price?
NFPA purchase
amazon purchase
5. How do I find out if my hours working in shipyards and boats qualifies as "relevant job experience"?
6. If I manage to turn into a real electrician, what's the possibility of joining a local union hall without having to start at the bottom? I have no idea how these things really work - I've been sold the pitch that "you test in at your level and are paid accordingly". It cannot be that easy. I was on an apprenticeship waiting list for two years (and moved three times) in my 20s.
Thank you for reading.
PS I read the evisceration of this guy. No, I don't think I'm qualified to become a master, but that's the only test available here as far as I can tell.
PPS My primary motive is self improvement, my secondary motive is I would love to stop traveling and have regular hours.
Source
2. How can this be?
NFPA purchase
amazon purchase
