Carultch
- Massachusetts
Some ask why two phases and neutral doesn't cancel like it does for systems with 180 degree phase angles. This doesn't really explain why but does show you the result is the same value for the neutral if the two phase currents are the same.
This is why:
You see another example of three vectors that are 120 degrees apart, and adding up to zero when they are all equal in magnitude. It's the same math problem, just a different application.
The two diagonal ropes carry 100 kg of tension (i.e. 980 N), and are supporting a 100 kg weight. Not considering the vector math, you might wonder why the tension in the two upper ropes is 100 kg, instead of 50 kg. After all, each rope should support half the weight. In a way, they do, because the vertical component of the tension in each diagonal rope is 50 kg. The fact that the ropes also pull mostly sideways in this arrangement, makes the tension in each rope twice as much as it otherwise would be, with two vertical ropes instead.
If you cut the left diagonal rope, the weight will no longer be supported in its position. Because a rope that is 120 degrees from the direction of the weight, cannot possibly hold it in place on its own. The weight will swing like a pendulum, until it settles directly below the support on the right. What once was a 120 degree angle, will become 180 degrees.
