And why is that?
Is changing out an LED driver any less dangerous than changing out a fluorescent ballast?
I thought the whole point of that rule was to help keep from having to work a repair hot.
Not that it really matters since I don't trust the disconnects that come with the fixtures anyway.
Every time I disconnect one of those yellow disconnects I feel like the wire is going to pull out and end up in my fingertips.
JAP>
Probably because no one submitted a proposed change to make the disconnect rule apply to LED drivers. The rule is very limited in scope at this time and only applies where the lamps are double ended.And why is that?
JAP>
I'd say people are much less likely to change a driver in a LED fixture, than a ballast in a fluorescent.
They are more likely to just replace the entire fixture since they are often so cheap, and the LED's themselves have a limited life.
And the LED drivers usually operate at a much lower temp. than ballasts did.
So I think LED drivers are both less likely to fail, and less likely to be replaced if they do fail.
