Dawn to Dusk Control
Learn the NEC with Mike Holt now!
FionaZuppa
AZ
Part Time Electrician (semi retired, old) - EE retired.
Ok, having a hard time finding this.
I need photo cell Dawn to Dusk plug-in for outdoor to run fountain(s) pump during daytime only. Only need one recept for pump plug, etc.
Anyone know of make/model that does day-on night-off? Don't need any more control than that.
FionaZuppa
AZ
Time clock is too complicated, they often lose settings, and do not really follow dawn-to-dusk hours closely, and then there's the ST and DT time change.
I am looking for a basic control, $30 tops.
If I can't find a simple control I will make it.
SSDriver
California
I'm a huge fan of the GPS light lock. They use a a GPS signal (Free with no subscription). You don't have to do anything, no programming, buttons or nothing. Just hook up power. It finds where you are and will turn on dawn to dusk based on satellite location, The nice thing about them they are not prone to having issues if there are other lights in the area that would turn a regular photocell on/off. I have only used the standard unit that looks like a photo cell. They sell a model that is plug in (pre-wired with enclosure, in-use cover etc). Made in USA too.
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
The owner of the Co is a member here to boot!
wwhitney
Berkeley, CA
Retired
The usual application is "dusk to dawn" for lights, while the OP is asking for "dawn to dusk" for a daytime only load. The GPS Light Lock spec sheet says "Custom builds, configurations and programming are available by calling toll-free (833) GPS-TIME (833 477-8463)." Would that be field programming, or require ordering a custom unit programmed at the factory?
For the OP, seems like a normal "dusk to dawn" photocell plus a relay to reverse the logic would work.
Cheers, Wayne
Buck Parrish
NC & IN
I have several on my fountains and bird baths . I use a contactor like Hal described They work excellent. In fact I should mass produce them.
For any body wondering why you need this. The pump motors last twice as long if you turn it off at night. Also the water only splashes out when the motor is running.
mopowr steve
NW Ohio
Electrical contractor
I’ve been using Honeywell astronomic wall timers for a while. They have automatic self adjusting dusk-dawn timing or programmed times with daylight savings time when needed and no batteries needed, and seem to keep time for a descent time of lost power.
Knuckle Dragger
Master Electrician Electrical Contractor 01752
Marlborough, Massachusetts USA
Great point!
The only downside of that is if you have an overflow drain on your pond and you also have a river that handles a lot of water.
When the pump is off all the water in the rive and hose dump back into the pond. you may have to replenish the water every morning if it over flows.
Of course this all depends on how the water feature is designed.
Buck Parrish
NC & IN
Great point!
Yep, I've got one of my pumps half way out on my boat dock. I just leave it hanging from the cord to keep it off the bottom. I have it pumping to an artificial creek that I made. The creek has been there so long it looks like it's natural. It has moss on the rocks, little water falls, ferns that come back every year.
When I first made it, the rocks I put there already had moss on them. So I watered my rocks.
My wife said I'm the only one that waters rocks. :) She sure likes it now though.
Todd0x1
CA
That thing is cool! one of those "why didn't I think of that" items....
sii
Nebraska
It’s mgookin. Looks like he hasn’t posted in a couple years. I helped him convert some cad files back in the day.
a.bisnath
Another option I have used is what is called
'smart timers', they have a battery back up in the unit so they do not lose the time if there is a power outage, found them on Amazon
