xptpcrewx
Power System Engineer
- Las Vegas, Nevada, USA
- Licensed Electrical Engineer, Licensed Electrical Contractor, Certified Master Electrician
Ok well you stated, "why POCOs always use two large transformers..."I'm very well aware not all POCO subs have two or even three transfomers, ie Con Edison typically has 5-10 transformers in a sub, however the majority of the time POCOs employ a two transformer M-T-M scheme.
Any idea why POCOs always use two large transformers in a substation?
Also, the number of transformers in a substation is not particularly important or interesting. You are failing to mention if those transformers are banked or not or related by arrangement.
Usually two units in a secondary selective arrangement provides adequate redundancy and capacity at the best cost while keeping complexity to a minimum.
Technical background?
