hacim23
Journeyman Electrician
- washington, DC
- Electrician
Does anyone see any sense in leaving set screws on bushings when they’re not being used as a bond bushing?
Ok, I just figured remove them and put in trash because if left on they need to be tight so then your putting bushings on and making sure (or not) that the set screw is tight when it’s not needed.Not worth the effort to remove. I have enough junk screws as it is.
We use metal bushings vs. plastic onesWhat is point of using a bonding bushing if you not using as a bonding bushing?
If it is all you have at the time being the only exception, in that case do what you want with the set screw and lug.
For larger feedersWe use metal bushings vs. plastic ones
Is all you can find the bonding type bushing?We use metal bushings vs. plastic ones
Half of the time you need to remove the screws to install the bushing so if they're already removed I would throw them away.
I put them on my nightstand. Once I get 100 and realize I’ll do nothing with them, they go in the trash.
Then next week you need one. LolI put them on my nightstand. Once I get 100 and realize I’ll do nothing with them, they go in the trash.
Instead of throwing away your pennies take them to the coin star machine in exchange for BitcoinI used to do that with pennies.
Why throw them away when the material they are made with is worth more than one cent?Instead of throwing away your pennies take them to the coin star machine in exchange for Bitcoin
