doje
- Fremont, CA USA
- Electrician
A friend owns a duplex that currently has two weatherhead‘s right next to each other fed by a single service drop from the pole. PG&E (local power company) no longer allows this scenario. In order to do a service change and install two new 200 amp panels, we have to do a single weatherhead with a 400 amp drop. Then it goes into a hot gutter which then feeds the new 200A meters and panels.
I know that if this was a single dwelling, I could use the 83% rule which would allow me to use 400 kcmil copper for the 400A service.
Am I able to still use the 400 kcmil and feed two services by splicing to 2/0 copper in the hot gutter? Or does the drop from the weather head now have to be fully rated at 600A @ 75 degrees?
My first post here so let me also add a big thanks for all the good info I’ve gleamed from this site over the years.
