I have two 20 KW Motors in a ware house freezer environment (-22F) . Both motors are used for lifts and fed by separate circuit 480V AC. Both motors have separate Lenze i950 drives (22kw) with 50A Class J fuse upstream. Issue is that when the systems starts working for some time then Fuse blows.
Motors are changed, cables are changed and drives are changed. Also during fuse blow, Drives are also damaged (replaced many drives). Last week all the upstream breakers are tripped and customer feed is also tripped. No short circuit is noticed . Any clues of what is causing the fuse blow and all the breakers and disconnects till the customer feed getting tripped?
