8 Gauge Wire 200 amp disconnect
mbrooke
Batteries Included
United States
Technician
Is 8 gauge wire on a 200 amp OCPD an allowable exception? What wiring method can be employed, ie does the wire have to be in a trough?
Line side tap, or the fact this is a substation battery charger and doesn’t count.
I guess you would have a fit to find out S&C motor operators have slugs installed in them rather than fuses..
Aren't these conductors protected at their source, the battery charger, at 50A, the 200 fuse is not part of their protection. Is this why you say they "don't count"?
I can do that; I assume the batteries deliver the power, and exclude the charger.
Question- how do I find out the short circuit output of a battery bank?
Ask the battery people. Batteries can pump out a lot of current in a dead short situation but it is unlikely to be tens of thousands of amps.
P.S. - what makes you think you can run cord from the charger to the 200 A disconnect?
What’s the amp hour of the bank?
90
.2(B)
that and 99.2(b)
That’s the charger circuit and it’s the way substation battery charger systems are generally wired.
Either that or direct to battery bank bypassing the disconnect, with a separate disconnect in the charger.
He seems worried about meeting code as far as the tap goes so why wouldn't he worry about the proscriptions on using cord.
90.2(B)
that and 99.2(b)
Typo and not paying attention... 99.2(B) was a screwup
we generally run an 8 or 10 gauge duplex red/black for the charger circuit.
90.2 is only applicable if this installation is a 'utility. I have designed and commissioned station battery systems like this for customer substations subject to the NEC.
Correct. If the substation is customer owned, the NEC technically applies. But in any case it is still nice to know you have something that won't present excessive hazard to vital assets.
