Smash
- Philadelphia suburbs, PA USA
I have a 3ph 240V 4 wire high leg delta incoming service. I’m hooking up a 45kva step up 480V wye transformer for a compressor. Do I simply feed transformer with the 3 phase delta 3 wires only ? Even if I have a neutral available. Then ground the X0 terminal and size it per my load that now is my equipment neutral. Obviously I’d supply additional egc and terminate all in transformer ground bar. Including base and structured steel.
