mpalatas
- Los Angeles, CA
- VP, Operations and Engineering - Chemical Processing
My company is an aerospace metal finisher. Our primary process is anodizing, which involves taking DC current and putting it through parts dipped in acids. To do that, we have DC rectifiers that put thousands of amps at fairly low voltages into anodes (parts) immersed in tanks filled with dilute acids. Cathodes at the sides of the tank take the current back to the rectifiers. I am trying to figure out the size of cabling I need to wire from the rectifier to the tank bus work.
All of the welding cable ampacity charts I find online show welding wire with 60% duty cycle, but some tables have 600V wire rating and some different tables that don't actually say what the voltage rating is.
Bottom line is that my applications are 100VDC or less, and distances from the rectifier to the tank connection are at 50'. I have a total load capacity of 4800A on one rectifier and 2400A on the other rectifier, and I want to keep the number of wires (positives and negatives) even. By most of the tables I found, that would mean (8) total 4/0 wires to the 4800A load, and (4) total 4/0 wires to the 2400A load. Can I get an independent confirm/deny?
Thanks!
Mike in Los Angeles
Thanks!
Mike in Los Angeles
