Daolin
- North East Florida
- Electrician
Hello there, First time poster but professional lurker. I'd like to start off with this. I've been doing electrical work for 20+ years with only on the job training and experience. I do have a Master License and strive to do everything 100% safe and right. I always attempt to figure out the right ways to do things from the code and have no problem asking other professionals how to do things the right way. I don't know all of the code like many of you do, but I do brush up on it every time I'm delving into something unfamiliar.
I'm an electrical contractor in Florida who is delving more into generators and have my first 400 amp transfer switch install for a 22kw generator (The customer decided to purchase everything prior to calling me out). I always like to get into new things and also am always willing to help people out. I am supplying pictures to see if what I am thinking of doing is doable.
There is an existing Meter/Main with 2 separate breakers to the inside of the home (1 is 125 amps, the other is 200 amps)
Stock picture of the Meter Cabinet
Real Picture of how the original service is
Home this will be installed at
My plan is to mount the 400 amp ATS to the left of the entire cabinet. I am going to take the line side on the panel breakers off at the load side of the meter and bring them into the ATS. I then am going to bring new wires off of the load side of the meter into the ATS. This will maintain the 125 amp and 200 amp breakers feeding the panels inside as disconnects.
The main concern/question I have is : Can I install polaris connectors in the meter cabinet so as not to have to mess with the tight 90degree bends from the factory in the meter side of the cabinet that connect to the breakers.
I hope this makes sense and appreciate any input and/or suggestions on an alternate method.
Thanks!
Todd
Thanks!
Todd
