- Tennessee NEC:2017
- Semi-Retired Electrician
When a 3-way switch circuit has been working and now only works if one of the switches is in a certain position, we know (usually) that one of the switches is bad. What I've been trying to come up with is a way to know which switch is bad without taking both switches out and testing. I wired a couple of 3-ways up on my work bench, , one being bad, to see if I could come up with something but could not as it depends on the switch positions.
What I usually do is just change both switches since they are most likely the same age, or try to find out which switch is used the most and check it first.
Anyone have a better method?
