Tulsa Electrician
- Tulsa
- Electrician
I was wonder which is it, a wire way or an auxiliary gutter.
May have covered before if so, sorry.
There is a separately derived system, secondary unfused feeding two panel boards and several branch circuits/ feeders inside an electrical room that all run though this ?. The transformer is on an opposite wall ran up and over into this( wireway or gutter). Which feeds the two panels with main breakers which also has additional conduit's ran into the ( wire way or gutter). Then pipes out of ( wire way or gutter) feeding branch circuit and other feeders. This enclosure if we call it that is above the two panels.
I ask because of the unfused secondary. They are not service entrance conductors. Thank you in advance. Base on 2104 NEC.
