fifty60_4802GND
- Ohio
- Engineer
I am looking for what I believe is called a flyback diode. The normal diode kit I would use is a Veeder Root diode kit 846000-022. However, the Veeder Root, like a cheesburger at McDonalds these days, is experiencing extremely long lead times.
The diode kit will be used on 24VDC solenoid valves. The controller that required the diode is recommending a Suppressor Diode with Ratings: Output Current of 1.0 Amp, Maximum reverse voltage 420 Volts
I am having trouble even finding a good vendor to ask questions to. Any suggestions on where to look?
