johnmstrks
- Mh11370!
- Engineer
The garage will have a subpanel with several circuits (lighting, exterior, car bay and wall outlets) all in EMT. It will be fed underground in PVC by 6/3 AWG w/ground. 230.79(D) calls for a minimum 60 amp disconnect. It seems this rules out the 50 amp circuit breaker at the main panel as a disconnect means as 6AWG is only rated for 55 amps. Where does the code require the 60 amp disconnect to be located? And, what type of disconnect means would be required? Two ground rods will be installed 6 feet apart with bare 6AWG.
Thanks again,
John
Thanks again,
John
