texie
- Fort Collins, Colorado
- Electrician, Contractor, Inspector
This changes everything. I thought you had 2 150 amp enclosed main breakers and the load centers were separate and could put the ATS in between. So you have 2 MB load centers connected directly to the meter can?if breaker is in panel and i want to run 2 main panel would i just get 2 150 amp service rate panels and tie them in together. There is no load side to put non service rated t switch because breaker is build into panel. is this correct thinking
Edit to add: I see that this is the case a shown in your post #3.
