Dsg319
- West Virginia
- Wv Master “lectrician”
I have installed submersible motor in a sump pump with both thermal switch, and seal leak detection.
From which it uses a 5VDC sense voltage from a probe inside to the metal chassis of the motor to test for leakage.. The product is a 8pin relay with adjustable settings. 201-100-SLD (will leave. Website for info)
I have no experience with this device, and first time dealing with sump pumps.
Question is, I have the seal leak detection conductors (everything single conductors) installed with the power conductors 208v/3ph, the sump pump only has 1port for entry. Do you think I will have problems with false seal leak detection due to induced voltages from the power conductors?
The common/input back to the relay that tells it there is a leak is bonded to circuit EGC from being attached to the motor chassis, will that take care of any induced voltages?
Fell free to correct me on anything as I really have not had much research in to how this thing works exactly.
m.littelfuse.com
201-100-SLD
<p>201-100-SLD is a single-channel, seal-leak detector with input voltage ac of 110–120 nominal and sensitivity at 4.7 k–100 kΩ.</p>
