WA_Sparky
Electrical Engineer
- Vancouver, WA, Clark
- Electrical Engineer
Hello all,
Typically whenever I design a dwelling unit plan (because of my commercial experience), I always default to 20A breakers and #12. I know many residential spaces end up getting 15A/1 breakers. I cant imagine the material cost reduction would be that significant since you can get bulk wire at discounted cost? Is the choice of 15A/1 over 20A/1 specifically due to material cost?
Second question. I have put a treadmill in a guest bedroom and it keeps tripping the breaker anytime I turn it on. I've figured out a surge protective device could be a potential solution. Even though that solution will work for me, I wouldn't want a future client to have to resort to that for a new build.
Do you think the problem wouldn't occur if the circuit had actually been 20A/1?
Do you think the problem is specific to the sensitivity of the AFCI breaker.
I may be totally in left field here, but ive been reading up on different types of breakers and their tripping characteristics (Type B, Type C, Type D). Do you think an alternate solution for preventing moderate inductive loads (treadmill) from tripping its breaker, would be specifying (or interchanging) the breaker with a Type C or Type D breaker for that given circuit?
I don't typically ever specify breakers this small unless there is a Fault current issue for series ratings so this whole type B,C,D is new turf for me.
Thanks,
Thanks,
