JDavidS
 - Bethesda, MD
 - Sytem Integrator (low voltage)
I'm in a discussion with someone about antenna discharge units for amateur radio stations.  Per the NEC:
810.20- Antenna Discharge Units - Receiving Stations.
(B.) Location: Antenna discharge units shall be located outside the building or inside the building between the point of entrance of the lead0in and the radio set or transformers and as near as practicable to the entrance of the conductors to the building. Antenna discharge units shall not be located near combustible material or in a hazardous (classified) location as defined in Article 500.
The question has to do with the last sentence regarding combustible materials. What does the NEC define as "near"? I can't find a definition anywhere. The other person says it is bo more than a Toaster, Oven, Heater, Coffee Pot, Christmas lights etc. I say due to the large voltages and current involved it has to be much farther. However, I can't find anything in the NEC which defines what they consider as "near" in this situation.
Can someone help point me in the right direction?
TIA.
TIA.
