Hello everyone. I have a similar application and am wanting to know what I can expect from my motor as far as running time at low frequency. I will be mounting this on a Powermatic 45 lathe with a Reeves drive, and a countershaft between the two. @Jraef I saw that you said not to expect better than a 1:4 drop from a motor that is not specifically inverter rated. Mine is not, but it is fairly old. So, I'm wondering if older motors can still be expected to drop that low. It is also a very physically large motor at 130 pounds, probably 14" in diameter, with a cast iron housing. So, I would expect this to work in my favor as far as cooling. I've attached image links of the nameplate and motor.
