When installing an ESS+solar is it always necessary to factor in the output of the ESS when considering the 120% rule of the busbar?
For instance, if you have an ESS that can output 40amps and you have 40amps of rooftop solar would I need to count the whole unit as an 80amp back-feed?
Does it matter whether the unit is set for time-of-use or just backup mode?
