BayElectric
- Bay County Fl
- Electric
Hello,
I'm required to change a miscellaneous panel, and in it there are 50A two pole breaker for irrigation pump, single pole 20A breaker for irrigation control, and two 20A single pole breakers for service outlets. I can't see the load or OCP on the pump since it submersible.
What is the minimum size wire allowed from the meter socket to the panel should be installed?
Thanks,
Thanks,
