Have a Federal Pacific TX40T51-A 208x240x480 pri, 400Y/231 sec 51KVA, using 240vac pri, and 400 sec Y config. When you throw the disconnect mounted on the side of transformer it will blow the breaker on the primary. We even hooked the primary direct to a fused disconnect feed with 125 slow blows in it and it knocked out our 200 amp main breaker. This transformer is drawing like up to 9 amps no load also. Odd thing is I have another FP trans that is 75 KVA setting right beside it and it never has blown anything and the highest leg draws a mere 3 amps. Fed Pacific claims nothing wrong I am mystified how one does this and the other one does not.
