robertpitre
- houma
- building inspector
Were can I found that gfic-wr in NEC code book, and do the gfic outside receptacles have WR on them? What is the difference between gfic and gfic-wr ?
Gfci-wr is weather resistant and there is a WR stamped into the device. With the P&S devices I believe the back of the receptacle is black while the NON- WR is grayWere can I found that gfic-wr in NEC code book, and do the gfic outside receptacles have WR on them? What is the difference between gfic and gfic-wr ?
I find it odd how many times I see WR GFCIs installed indoors.Always good for a red tag when someone doesn't pay attention and installs a indoor gfi where a wr gfi should be
I've seen lots of GFCI's installed outdoors. Almost all of them have been indoor GFCI's.Always good for a red tag when someone doesn't pay attention and installs a indoor gfi where a wr gfi should be
The change was recent enough that I don’t expect to see a WR device.I've seen lots of GFCI's installed outdoors. Almost all of them have been indoor GFCI's.![]()
We've been doing it for several years. Not sure when the change was made.The change was recent enough that I don’t expect to see a WR device.
I believe the WR GFCI's are a little more expensive as well and I only use them for exterior use.I find it odd how many times I see WR GFCIs installed indoors.
Rob G
I always use antiseize on any fasteners installed in damp environments. And antiox on all electrical connections.how many have went to replace an outdoor outlet, doesn’t matter if it’s regular or GFCI? Rusted in place normally. And the screw breaks off in the box, then your stuck either replacing the box or engineering some other solution..
The yokes and screws are different on the WR GFCI.
Great, that won’t stop the yokes or the screws used for interior GFCIs from rusting out though when they are installed outside…I always use antiseize on any fasteners installed in damp environments. And antiox on all electrical connections.
I wasn't suggesting that I use interior GFCIs in damp environments.Great, that won’t stop the yokes or the screws used for interior GFCIs from rusting out though when they are installed outside…
Only if you want to get them apart again.I wasn't suggesting that I use interior GFCIs in damp environments.
Btw, anti-seize is particularly important on stainless to stainless threaded connections.
When I was a teen working on a car, I had an unfortunate experience: I was assembling a stainless nut to a 1/4" stainless bolt and the two parts galled and seized together before they were even fully assembled. Trying to wrench them apart caused the bolt to shear.Only if you want to get them apart again.
