- Tennessee NEC:2017
- Semi-Retired Electrician
If you have a normal laundry area on the main level of a house and there is an additional stacked washer & dryer on another level, are you required to treat the additional area as a laundry area? I know even if the appliances are a stacked unit in a single laundry area and only needs a 30A circuit for both, we have to also run a 20A circuit. But would a 20A circuit be required for the additional laundry equipment even though a 30A is all that is needed for the equipment?
