xformer
- Dallas, Tx
- Master Electrician
In article 362 of the NEC, ENT is not permitted to be used in Theaters. Can someone shed some light on why this is the case?
See 520.5(A).In article 362 of the NEC, ENT is not permitted to be used in Theaters. Can someone shed some light on why this is the case?
This does not explain why, just prohibits it. I suspect like many things someone thought it was a good idea and somehow it ended up in the code.See 520.5(A).
Yeah, that just tells you why it is in 362, but does not address the reason that it is in 520.This does not explain why, just prohibits it. I suspect like many things someone thought it was a good idea and somehow it ended up in the code.
I have found using a nylon fishtape makes a big difference, and tight strapping, but yeah, steel fishtapes and Smurf tube don’t work well together.And a note. ENT is hard to pull through and od is larger than mc or ac,if you are drilling studs.
