what kind of ohms reading are you getting? if it is multiple megohms that basically is an open circuis
what is the reading and what conditions are you in ( inside dry, outside wet, underground, etcsorry for late responses and I wrote this post in a hurry. I would still like to get help with this question. I am using a simple voltage meter with ohms/continunity setting. I have a green white and black wire open at both ends. I put meter on continuty and I connect wires at one end I get continunity between wires. if I put meter on ohms setting and I leave wires open at one end and put meter on wires at other end I get ohms reading without any wires touhing. I am getting ohms reading without any wires touching. Is normal to get ohms reading through wire without it touching anything?
Check for voltage between the conductors. If the conductors are running close to conductors with voltage on them, there can be enough coupling to put a small voltage on conductors that are open at both ends. The voltage will cause an ohm meter to show resistance.sorry for late responses and I wrote this post in a hurry. I would still like to get help with this question. I am using a simple voltage meter with ohms/continunity setting. I have a green white and black wire open at both ends. I put meter on continuty and I connect wires at one end I get continunity between wires. if I put meter on ohms setting and I leave wires open at one end and put meter on wires at other end I get ohms reading without any wires touhing. I am getting ohms reading without any wires touching. Is normal to get ohms reading through wire without it touching anything?
I agree.I would also caution against reading too much into a continuity beep. All that means if the resistance was low enough for the meter to decide there is continuity. When you are scratching your head what's happening, you need to be on resistance and not continuity.
If you are holding the leads with your hands and they are touching the wires then you will read resistance thru your body
You still didn't state what the reading was when the ends were free
Sure wouldn't be the first or last time.Post #6![]()
