For Commercial purposes, We have a small customer that needs to install three separate solar systems (each 5KW DC) for 3-customers, and the Point of Interconnection grid had available 3-phase voltage (277/480V AC). and I found the Inverter SMA that had a nominal voltage range is 3/N/PE; 220V/380V, 3/N/PE; 230V/400 V, and 3/N/PE; 240V/415 V.
I am wondering if there is an issue with the Point of interconnections. Does this work for Point of Interconnection or Not? If yes, is there any issue for Inverter to get trip (turn off and turn on due to the voltage range)
Appreciate your help.
